asked Feb 9, 2001 at 5:36am
Hp HP LaserJet 4
Hp LaserJet Trouble :(
Hp laserjet 4 comes up with "53.12.08 Error" on the LED display, if you manage to reset the printer, it says ready but no application can print to it and windows says the printer is not responding. I haven't been able to determine if this is a hardware error or if its on the software end because i can't find any documentation for the error anywhere. Any one got any clue as to what this could be??
53.12.08
This is a memory simm problem,
Do you have any extra memory simms installed?
If so, Remove them and restart your printer
If it works ok, that will tell you that the memory simm is no good and needs to be replaced
This can also happen if you put a memory simm for an HP LJ 4+ into an HP LJ 4
Good luck
by Ray on Feb 9, 2001 at 6:54am Add comment
