asked Jan 23, 2003 at 8:52am
Epson Epson Artisan 700
Epson Stylus Photo 700 Misalignment
I have a Epson Stylus Photo 700 that worked great until..
about half way done the page, the printer seems to forget where the center of the page is and moves the 'center' over to the left about 4 inches. I have tried using the software to realign it, but it keeps happening. Its so bad that the printhead sounds like it bangs into the left side of the printer and gears grind and all sorts of inkjet goodness.
And now it awaits the scrapheap, unless anyone has suggestions?
i have an epson 1200 and the smame thing happens. i'm running Mac OS 10.2 and when i boot into 9 it doens't do it anymore, so i know it has to be a cimmunication error. i don't know what caused the error in the first place, my orinter has printed fine in 10.2 before.
let me knwo if you hear anything
-a
by unknown on Feb 16, 2003 at 7:49am Add comment
Is the carriage rail sticky? This may be a lubrication problem where the printhead carriage is sticking on the travel rail. Does it look dull and dirty? Best bet would be to remove the rail, clean it and re-lube it with silicone oil or equivilant.
davemac
by davemac on Feb 19, 2003 at 10:03pm Add comment
I cleaned the carriage rail and watched in amazement as my Photo 700 worked perfectly. Something it hadn't done for about six months.
Thank you very much
by unknown on Apr 26, 2003 at 5:46am Add comment
what did you use to clean it, and then what did you use to reoil it?
thanks
-a
by unknown on Apr 29, 2003 at 4:52am Add comment
