asked Jan 9, 2012 at 2:59pm
HP laserjet P2030
This HP laserjet P2030 I have is printing fine except it prints crooked on the sheet. All of the print is inclined
rising left to right 3 or 4 mm sometimes a little more or less…pretty consistent though.
Sometimes the top right corner of the page is bent. Otherwise the sheet is straight and not wrinkled.
I checked the rollers and saw nothing obvious. Any suggestions would be appreciated.
The top right corner sometimes bent would indicate an issue of a paper shred or some other small object impeding the paper movement and causing the sheet to skew. Try feed from the manual feed and if the same then check inside by the registration assembly. If ok from the manual feeder then check the feed path from the paper tray up to the registration assembly.
I forgot to mention that I did print from the manual feed and the page was perfect. - unknown
