asked Dec 17, 2011 at 11:01am
Hp HP DeskJet Plus
Totally frustrated
I recently had to re-install HP Photosmart Plus B209 (a-m) since then whenever I print a photo it appears to be moved to the left and a white strip appears. However on the preview it appears correct. Have tried changing the setting, tab, picture size etc. with no change. Did not do this prior to the re-install. Even tried re-installing again . set all setting back to factory default. Trying to simply print some holiday photos but half a body is cut off each time. Help would be greatly appreciated...
