blarge
asked May 26, 2011 at 11:55am
FIXED!!! HP LJ 9050 Skewing from Manual Tray on Duplex
I have 2 HP LJ 9050 Brand New just out of the box. One works flawlessly, but the other is skewing intermittently when duplexing from the manual feed tray. This does not happen on Trays 2,3, and 4. I have swapped out the following from the good machine: Duplexer, Manual Feed Assy, Diverter, and Toner Cartridge. None of this seems to help. Also when I swapped the parts the machine that works did not seem to flinch at the different parts. The only things I have left to swap would be the 2 doors from either side of the machine, and maybe the solenoid that controls the diverter. Anyone seen this or have any suggestions?
Figured it out. Adjust registration from the setup menu.
