asked Jul 11, 2010 at 12:12pm
Hp HP Color LaserJet 2840
HP LaserJet 2840 install supplies error
Printer gives me install supplies error, while cartridges are installed. Whenever rotating cartridges and just working making scraping noise. Exclamation mark is blinking orange. Thank you for your time and help!
Do you have the hp toolbox software loaded for this printer. If you do run it and it should tell you what supply needs to be replaced. It could be any of the color toner or the drum unit which needs to be replaced. Had you gotten any message previously telling you one of those item was low? If so it is probably that item that needs to be replaced.
by unknown on Jul 12, 2010 at 4:46am Add comment
