asked Nov 3, 2002 at 7:40am
Hp HP DeskJet 600
HP OfficeJet 600
I have a HP OfficeJet 600 and i've been having that paper jam problem...i tried cleaning the plastic guide strip and it didn't help, so i took it apart and looked at the gear system on the left of it, and it appears that the gear that drives the fax paper feed, and the printer paper feed doesn't move when it has to. the coil that kicks out the bar that moves the gear works, but maybe there is suppose to be a spring or several springs? if anyone knows has a solution or knows where i can get a picture or diagram of the gear system for the paper it would be greatly apperciated. Thanks
