jim
asked Jan 17, 2001 at 8:56am
LW2 paper offset
When I print from the paper tray on my Apple LW2 there is a 1" extra margin added to the top-ie the paper is shifted down about an inch. It works fine on manual feed, and I've tried all software solutions. Is there an adjustment for the paper feed from the tray?
jim
jim
There aren't any adjustments. The pickup roller picks them both up at the same spot. The MF is just a fraction of an inch higher up, but other than that there shouldn't be any difference. Try an engine test and see if the print is centered from the cassette. If it is, then it would be a software issue.
