asked Mar 19, 2010 at 10:11am
small piece fell into printer
A little piece of plastic fell into my Epson 710(a few millimeters in diameter). I am not sure where it is, but it hasn't caused any printing problems so far.
I turned the printer upside down and gently tipped it back and forth, but could not hear or locate the piece.
Should I do anything else? As I said, the printer is working fine, but I am worried it might get damaged if I don't make sure the piece is removed.
Thanks.
Thanks.
About the only thing you can do besides tearing it apart is to tip it upside down and do what you did. Typically I dont worry about plastic. Metal is a different story you dont want that to get on a board. So I probably would say your safe. The machines are pretty strong and theres not really to much in there to get damaged.
