hiker
asked Jan 30, 2010 at 4:19pm
Hp HP LaserJet 6P
HP 6P - paper jam problem at cartridge
ok.. paper stops moving through my 6p after about 1-2 inches have passed the cartridge. I have a solid black area on the paper that has passed.
reading the forum, it seems clearing around the paper sensor is a frequent solution. so i took the cover off, and blew air around and in the hole with the paper sensor. the little sensor arm moves easily.
nothing changed. so what's my next option?
TIA
nobody even has a guess at this??
by hiker on Feb 13, 2010 at 11:26pm Add comment
by hiker on Feb 14, 2010 at 12:44am Add comment
If you look on the left side, there is a small drive assy. If the paper has reached that, then that would be the problem. You would need to replace it. Really difficult job as you have to dismantle most of the printer to get it out.
by moe on Feb 14, 2010 at 8:40am Add comment
