rafenn31
asked Jan 16, 2010 at 4:56pm
Hp HP LaserJet 4
HP 4P Paper Jams- -what is problem - ho do I fix.
(1/16/2010 4:48 PM) reply + / -
Occsionally, my 4 4P is jammimg during a print job, May happen after a few pages or printing a tray. Here is what is happening:
While printing is in process, sometoimes a paper will not get out of tray and printer jams. This is easy to resovle - remove paper tray and misfed sheet. Usually, while in print job, it jams. Jammed paper can be seen coming out as a finished print but only 2-3 inches of paper can be seen- There is print on this section of paper. Then printer jams and stops.
To clear, must open back door, and carefully pull jammed paper out.
I recently replaced cracked motot gear. Worked fine. Chekced pick up roller, looks ok.
Any suggestions will be appreciated.
Ron
