daveandvik
asked Nov 12, 2009 at 8:01pm
Hp HP LaserJet IIIP+
laserJet IIIP repair question
My HP Laserjet 3P prints and there are no error messages. Paper pickup is OK. No unusual number of jams. However as the printer is printing it has developed a stutter in the printing action. You can hear a click every few seconds and you can see the rollers stutter. The result is the paper is not feeding smoothly and print on the lines when the click is heard is distorted.
You can hear a thump about every 3 seconds and the rollers stutter and the printout gets distorted.
I used your service before on this printer and parts and instructions I got were perfect. I've gotten years out of this printer and would to get more. Hopefully you can help again.
Hope you can help.
Check the white gear on the lower right in this photo. http://www.fixyourownprinter.com/reference/guides/fuser/lx
by moe on Nov 12, 2009 at 10:47pm Add comment
Thanks for the quick response. I was able to extract the fuser assembly as you described and...
Yup,
The white gear is missing some teeth causing the stutter in the paper feed and the smeared printing. Is the gear a replaceable item? Other than the gear, the fuser seems to be in good shape.
If the fuser needs to be replaced, what do you suggest?
Also, there is some grease on the gears and it is pretty dryed out. What is the recommended type of grease to use for the gears?
by daveandvik on Nov 14, 2009 at 8:19pm Add comment
Grease isn't necessary. We should have those gears in stock. Send an email to [email protected] and they'll respond on Monday.
by moe on Nov 14, 2009 at 9:00pm Add comment
Thanks a bunch. I was able to remove the gear and will contact the sales department for a replacement.
Regards,
by daveandvik on Nov 14, 2009 at 10:04pm Add comment
Regards,
by daveandvik on Nov 14, 2009 at 10:08pm Add comment
