rogermatrix
asked Aug 15, 2009 at 12:57pm
Problem in HP 2840 - HELP !!
My Color Laser is just beyond it's warranty.
Only had a carousel alingment problem, the printer was working fine, except for the print result, was working well on its other functions.
So, i fixed the alingment problem and after close the machine, I got "59 0C error". tried on/off and the same error again.
There is a noise at the carousel-engagement motor, because it stops at a gear's flag and the motor try to go on, force , and as it can´t, makes a bad noise and stops for security, after 2 seconds.
This gear with flag is part of Carousel pressure (support) assembly (RG5-7589-000CN)labeled at manual Gear, 25T (A42)
Everything seems ok. nothing broken or damaged.
Can anyone help ?
Can anyone help ?
