asked Jan 2, 2001 at 12:02pm
LaserWriter Pro 630 Green LED
Hello. I have a problem with the green LED on the side of my LaserWriter Pro 630. It simply does not work. The printer works fine.
When powered up, the two yellow lights come on, and then go off. I assume the red light works, but have never seen it light.
I took the little LED Board out of the printer when I took it apart to fix a recurring paper feed jam. That was successful, but once put back together the green LED does not work. (It worked prior to the disassembly.)
I assume I've blown the actualy LED. When can I purchase a new one? Something else to try to fix it? I imagine I will have to purchase the four LED board that plugs in.
Thanks in advance! Doug
