Dale
asked Jan 2, 2001 at 11:19am
Stripe on Series II
There is a 3/4" dark stripe down the left side of print on my HP LaserJet Series II. It is not VERY dark, but it is noticeable. It is darkest in a 3" long patch that starts about 1" from the top of each page. When I try to clean the paper path the strip is lighter (but still moticeable) for a few pages, then it grows darker again. I am hoping someone can give me some advice about where else to clean. The problem started last night, when I took an old cartridge out and shook it a little to try to wring a few more pages out of it. Now I have a new cartridge in, but the problem persists.
Also, I seem to have lost the little green brush that goes inside the printer. Anyone know where I can get a replacement?
Dale
Would seeing a print sample help to diagnose which is the problem? I scanned and posted one at http://www.lions.odu.edu/~demiller/printer.jpg. If the problem is worn teflon, then would it tend to become noticeable slowly, rather than all at once? Would knowing that this printer did have some toner spilled inside at one point (got moved with a cartridge inside) suggest a third possible cause?
Dale
With further experimentation, I have noticed that the problem will essentially go away for a few pages if I turn the printer off and let it cool. After a few pages, when it starts to warm up, the stripe comes back. (This explains why cleaning it seemed to temporarily solve the problem, even though I cleaned a different bit each time!)
Dale
Yes, I did. THat makes it definitely a bad cartridge? Shoot, it was brand new too. One made by Xerox.
Dale
Although it's likely that it's a bad drum,
it's curiuos that the problem started
by removing and re inserting the cartridge.
These printers have a spungy "bumper" in
the cartridge holder area near the back.
It might be loose and blocking the laser's
optical path. make sure the 3 black screws
just above the cartridge are'nt loose.
They hold the shutter assembly which closes
when you remove the cartridge. (a safety thing)
Thanks again,
Dale
The new cartridge ($32, made by Solei, if I am reading it correctly) solved the problem completely. I wonder if I can get Xerox to take back the defective one. I bought it long enough go that there is no chance I will still have the sotre receipt. THanks, everyone, for the help.
DEM
DEM
