asked Jan 1, 2001 at 11:22am
IBM 4019 Power Switch
My power switch on my old IBM 4019 Laser printer pushed in through the front panel. It still works but will not stay in the front panel. What holds this switch in place?
Remove front white plastic cover that is holding panel leds. Careful not to tear ribbon cable to LED panel. Plastic stop/holders on front panel that holds white plastic switch lever are broken. A long 8x32 hex screw will fit thru middle of lever. Measure/mark on inside and drill a inset hole for hex screw to swivel.
