asghar
asked Jan 31, 2009 at 10:45am
Hp HP LaserJet 6P
HP LASERJET 6P (C3980A) POWER SUPPLY
HI ALL,
I HAVE A LASERJET 6P IN VERY GOOD CONDITION. BUT IT IS 120V INPUT. WE HAVE 230 V ON OUR WALL OUT-LETS. I WANT TO CONVERT THE POWER SUPPLY FROM 120V TO 230V. CAN SOME BODY HELP ME? AND I NEED CIRCUIT DIAGRAM FOR THE POWER SUPPLY TO UNDERSTAND AND CONVERSION.
THANKS
ASGHAR
Recommend you use a step down transformer. Not only does the power supply need to be changed but the fuser which has a heating element would also have to be changed. Step down is the best bet. See the link below and would recommend ST200 which is 200 watts.
http://www.starkelectronic.com/st500.htm
by dmzcompute on Jan 31, 2009 at 12:31pm Add comment
THANKS,
PROBLEM HAS SOLVED.
ASGHAR
by asghar on Feb 3, 2009 at 12:00am Add comment
