Rono
asked Dec 11, 2008 at 12:54pm
Hp HP Color Copier 120
HP Color LaserJet 3600dn
this printer was connected to 220 volts. The printer is made for 120 volts ac. The printer is now dead. I checked the power supply fuses they are OK. I can see where one capacitor over heated. I suspect that power supply is damaged. I have some technical skill, I know how to test components.
What do you think the problem is. Should I try to repair the power supply or replace it?
Not only the power supply but you also probably blew out the fuser assembly. Since the printer is only worth about 300.00 us I would think it is not economical to repair.
by dmzcompute on Dec 11, 2008 at 5:18pm Add comment
