Martin Mann
asked Sep 15, 2008 at 8:16pm
Epson Epson Stylus Color 740
Epson 740 Color Printer
This printer is about 8 or so years old and has worked perfectly until the other day when suddenly the color printer stopped printing the yellow and magenta; it still printed the blue. In addition, the black cartridge showed empty. I replaced both with new cartridges and altho the black printed OK, the color still only printed the blue. I tried a second new color cartridge with the same results. I cleaned the heads innumerable times with the same results - only the blue printed. Any comments of what I can do to correct this problem? I have made approx. 25,000 copies, predominently black so it is far from being at the end of life - or is it? Is it worth repairing? I have changed cartridges in many a printer including this one over the years with no problems. Marty
It sounds like the printhead has become clogged. You should consider purchasing a cleaning kit from this website. Hope this helps.
by unknown on Sep 15, 2008 at 8:47pm Add comment
I have the same problem. I have cleaned the heads many time with the solution they sell on this site, but only the cyan prints. (cleaning did get the cyan printing, as none of the colors printed before that). Is there a way to remove the cartrige holder and clean it from the bottom?
by toolman3 on Dec 29, 2008 at 5:34am Add comment
Do not remove the print head. It is completely unnecessary and you break the factory adjustments. Put a pool of the cleaning solution on the cap assembly. Then slide the carriage over it. This will soak the face of the print head and you don't break any adjustments.
by Anonymous on Dec 29, 2008 at 9:19am Add comment
Thanks, I will keep trying. - toolman3
