asked Nov 20, 2007 at 7:11am
Hp HP LaserJet 3100
HP 3100 fax
I have the paper feed problem-- but this is a stand-alone HP 3100 Fax, not a printer, not an all-in-one. Will the fix it kit work for the stand-alone fax? (The kit that says paper feeds from the back of the machine)?
thanks,
Reid
Reid,
Is it a HP Laserlet 3100 printer that use only as the fax ?
Cheers,
YP
by Ypshec on Nov 20, 2007 at 7:52am Add comment
If it's a LaserJet 3100, then it's an all in one machine.
Many people have them set up where they only use the fax functions.
If it pulls two or more blank sheets at a time it is fixed with:
http://www.fixyourownprinter.com/kits/hp/K38
If it pulls two or more of the sheets being faxed you need:
http://www.fixyourownprinter.com/kits/hp/K80
by Stephen on Nov 20, 2007 at 8:12pm Add comment
