greenego
asked Sep 24, 2007 at 12:40pm
Hp HP LaserJet 4SI
HP 4SI Not Reading Out of Paper
When the paper trays on my 4SI run out of paper, the control panel still reads READY. This is happening with both trays. When I remove a tray, I get the correct information, UC/LC Tray Empty. When the upper tray is empty, the printer tries to feed from it causing a jam. I have to remove it so the printer will default to the lower tray.
Sense this is common to both trays, I am assuming its a problem with a board. Any Ideas?
