criss
asked Jul 18, 2007 at 8:37am
Problem with HP 2840 (Q3964A) drum/transfer unit
I have a problem with an HP 2840 AIO after remanufacturing the drum unit. This - http://www.tonershop-bg.com/pix/troubleshoot/HP2840.jpg is the first demo page after the remanufacturing of the drum unit. Then I copied a blank white page and the copy was this - http://www.tonershop-bg.com/pix/troubleshoot/HP2840_copy.jpg When I took out the drum unit of the 2840 the image was still on the surface of the transfer belt but not on the OPC.
I opened again the drum unit. Cleaned the transfer belt, replaced the wiper blade but the result was the same.
Does anyone have an idea what could cause this?
Thank you!
Thank you!
