asked Feb 8, 2007 at 4:10pm
Hp HP LaserJet 1200
replacing fuser in hp laserjet 1200
I have installed a new fuser, but I have one wire that I can't reconnect. It doesn't plug into a port, it is a slide connector of some kind. There is only one place for it to attach, but I can't figure it out!
If it has a metal end on it it goes on the right side.
Cheers.
Bill
by theprinterman on Feb 8, 2007 at 4:57pm Add comment
Probably the grounding wire on the right side. Look up on the right where you see some metal in the black frame and the metal at the end of the wire slides up the black frame to engage that metal piece on the frame. Download the link below and blow up the picture and it is item 3 that needs to be put in place.
http://download.yousendit.com/B0982E06307476E4
by dmzcompute on Feb 8, 2007 at 7:10pm Add comment
