asked Feb 6, 2007 at 2:08pm
Hp HP OfficeJet 7210
HP 7210 All-in-one .....Unable to copy
I went to use the copier,received three messages
First: Paper jam,
What I did to correct:I removed it, then I received second message
Second: Carriage stalled
What I did to correct: After several tries and researching how to fix I came across this website. Using distilled water and Q-tips and coffee filters,I cleaned the carriage rod, the ink cartridges connectors and mylar banding.
Results: I'm now receiving a message that the paper is the wrong size and then it goes back to carriage stalled
I also tested printing from the computer and had no problem here.
Thank You
If it prints from the computer, then the carriage stalled message when copying makes no sense.
After you clean a carriage rail you have to relubricate it.
All about carriages:
http://www.fixyourownprinter.com/forums/inkjet/42029#2
Is there any other information with the wrong paper size message?
by Stephen on Feb 6, 2007 at 4:21pm Add comment
