tylertyler
asked Aug 18, 2006 at 11:35am
Hp HP LaserJet IIIP+
HP IIIp Error 52
My printer was working fine until I replaced the toner cartridge. It then put out one test page and now I hear the motor wind up, then stop, then a Error 52 appears. Alt reset doesn't work.
Do I really need a new scanner motor or could I have messed something up when I replaced the toner?
The scanner motor is totally independent. No way you could have messed it up. Pure coincidence. You do have to replace the scanner motor assy. Check the Printer Repair Kits section.
by moe on Aug 18, 2006 at 11:59am Add comment
