asked Jul 19, 2006 at 8:27am
Hp HP LaserJet 4100
HP 4100 STARTUP
On turn on my 4100 checks the memory the stalls before geting to a ready state, I have tried known good swapouts for the ROM and memory chips to no avail any other Ideas out there or is it a dead planar? Thanks in advance.
If you have a jet direct card, remove it and see if it boots. Next try and cold reset by holding down the big green button while powering on and continue to hold until cold reset appears in the menu. If you have indeed tried a new firmware chip and the other things I mention and still does not work, then the formatter itself is probably bad.
by dmzcompute on Jul 19, 2006 at 2:12pm Add comment
