JudithKD
asked Oct 12, 2005 at 2:26pm
Epson Epson Stylus Photo 2000
Epson 750 color stylus, windows 2000 custom forms?
Hi.
I need to print labels that come in a 9" sheet. Is there any way that I can specify a custom form on this printer? Or, should I cut the form in 1/2? (I can, it's perforated.)
Any input would be helpful!
Thanks.
Judith
you can creat a custom form in the printer and faxes window by going to File then Server properties, then when your in the print window of the program just select your custom form, that should work, but be careful Epson printers dont really like labels, well the one that you have. but this should work. I know I used to work for Epson.
Good luck!
by Lauren on Oct 12, 2005 at 2:39pm Add comment
Lauren,
Thanks. Part of the problem seemed to be the software I wanted to use, Filemaker. There's no custom provision available there. Word on the other hand allowed me to define a document the correct size. Now whether I can get the stuff to print?
That's another question!
Thanks for the response. I wish I had thought of this board sooner.
Judith
by JudithKD on Oct 12, 2005 at 2:57pm Add comment
