Kamesh
asked Jul 10, 2005 at 7:33am
Epson Epson Stylus Pro Pro
Epson C43 SX - Unable to print in draft mode
I am unable to print documents in draft mode while text and graphics mode works fine. If I attempt to print in draft quality the printer just hangs. I even downloaded new drivers for Xp Pro but no help.
Anyone can help me? Thanx.
hi, my printer is epson stylus c43sx and it doesn't print.the red and green light keeps on blinking.i have tied to change the cartridge but still doesn't help.may somebody try to assist me.
by unknown on Sep 8, 2006 at 3:00am Add comment
Kamesh: Unfortunatly, its probably not actually a problem in the printer itself, but more likely a problem in your computer system and most likely in the software you are trying to use. Most Epson Authorized Service Dealers are not actually trained on the newer "C","CX", "R" or "RX" models, so I can't really be of any actual help to you. Just in case no one else is able to help you, I wanted to let you know, that you may be able to get help directly from the "Epson Technical Support Department". At least that way you are dealing with a technician thats trained on your particular model, by Epson Company. To see available phone numbers for technical support, go on-line to Epson @ " http://www.epson.com ", or call the Epson Automated Support Locator @ 1-800-442-2110 [press 1, then 1 & following prompts]. If your printer is out of warranty, you will need a credit card, before the technicians can help you, because there is a charge for technical support over the phone. You can also e-mail the "Epson Technical Support Department", for possible free help or advice, at http://www.epson.com and then click-on "Proceed With E-Mail". They state on their web-site, that they "will respond via e-mail within 1 business day"...Good Luck! Denny Conway
by Denny Conway on Jul 12, 2005 at 5:23pm Add comment
please help me my problem!!! my printer led is blinking red and green. can you help me how to solve my problem? please.....
i need your reply to day..
by unknown on Mar 21, 2006 at 8:27pm Add comment
my printer is epson stylus c41sx and c43sx
thank and more Power!!!!
by unknown on Mar 21, 2006 at 8:31pm Add comment
i saw on another forum that this blinking lights indicates that the waste ink deposit it's full and you need to changebut i don't figure out how??? so it that we're going half the way don't you think????
well!! REGARDS AND GOOD LUCK!!!
Post me the answer if you find out how!!!!!!
by unknown on Oct 10, 2007 at 8:04pm Add comment
by dyzeck22 on Oct 10, 2007 at 9:55pm Add comment
HI.. MY EPSON C41SX HAVE A PROBLEM....
IT DONT PRINT ANY THING BUT WHEN I SWITCH ON THE POWER THE RED LED IS ON AND THE GREEN LED IS BLINGING......
SO PLZ... SOME ONE KINDLY HELP ME OUT OF THIS.........
by unknown on Nov 23, 2007 at 9:29am Add comment
