vookster82
asked Feb 16, 2005 at 2:11pm
Hp HP LaserJet 5SI
HP 5si MX tray 2 lift problem
Hello, i have an HP 5si mx that has a problem with tray 2 not lifting. When i open the front access panel / door. I see that the tray is not lifting. This results in the error "tray 2 empty" even though its not empty. It only prints when the tray is topped off with paper (or i toggle the paper flag sensor up)...but then stops and errors out after a few pages are printed. I tried switching the trays but that did not work. The black plastic paper flag sensor inside works properly. It seems that the actual problem is with the black thing a ma jig that actually lifts the tray up. The tray moves freely so i know the tray is not the problem. Any suggestions? Thanks for your time.
You need to replace the complete PIU.
by dmzcompute on Feb 16, 2005 at 2:28pm Add comment
Are you sure? What does it cost and are they a pain to replace? Ill take a look in the manual for info. Any suggestions as to where to buy it from? new / refurb? Any and all help is greatly appreciated. And thanks for the quick reply
by vookster82 on Feb 16, 2005 at 2:58pm Add comment
Not that easy, but then again not that hard. You can get a refurbished unit from either partsnow.com or depot-america.com on adavance exchange. They cost about 135.00. They may have the manual on this site or if not and you decide you want to try it, email me and I will send you the pdf for disassembly.
by dmzcompute on Feb 16, 2005 at 4:01pm Add comment
allright, ill look into it probably tomorrow or over the week end. Thanks a bunch - vookster82
