asked Oct 22, 2000 at 4:47am
Laserjet IIP Plus memory upgrade
I have installed a 4Mb memory board in my Laserjet IIP Plus but when I start the printer (after the computer) doesn´t identify the memory upgrade and the printer works only with the standard 512K, giving me continous Error 50 and 20, untill I restart the computer and switch off the printer. When I start firtable the printer and then the computer there is not problem. How can I solve this problem in order to be able to start the printer with 4Mb whenever I want?
Did you put the upgrade in with power off? Are you sure it's a good board? Try reseating it, sometimes they don't go in all the way on the first try. The error 50 is a fuser error and has nothing to do with the memory. Did you do a test print when it did work and confirm that it is in fact seeing 512K? What does firtable mean? I've been trying to figure it out, but can't.
