asked Sep 8, 2004 at 2:48am
Epson Epson Stylus Photo 2000
EPSON ACULASER 2000 ERROR MESSAGE
HAVE GOT AN EPSON ACULASER 2000 WHICH IS SHOWING
ERROR MESSAGE C0084- ANY IDEAS HAVE TRIED SWITCH
OFF/ON AGAIN BUT NO JOY ?
Because the "Epson AcuLaser Color 2000 Laser Printer" was specially made for Latin America and usually also for the UK areas, I've never seen one and of course, don't have a reason to even have a Service Manual, here in the USA. I'm sorry, but there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the "C" = Controller Related Service Call Error Message and the "0084" = a "CPU Error (Address Error Exception [Load/Fetch]). As to what that actually means, I'm sorry, but I do not know. At least you know what the Error Code is and the area that it refers to. I hope someone that is framiliar with your printer, may be able to help you further. You can always E-Mail Epson Technical Support for possible help, at www.epson.com and then click-on "Proceed With E-Mail". They state on their web-site, that they "will respond via e-mail within 1 business day"...Good Luck! Denny Conway
by Denny Conway on Sep 8, 2004 at 4:58pm Add comment
CHEERS FOR THAT INFO DENNY, EMAILED EPSON TECH
SUPPORT (UK) EARLY YESTERDAY BUT HAVE HAD NO REPLY YET,
by unknown on Sep 9, 2004 at 1:18am Add comment
I had same problem and replaced the memory and it started working again.
by unknown on Sep 10, 2004 at 1:51pm Add comment
we use a epson epl2700 and get the same message Epson said unplug the unit and clear the print que once this is done reconnect it in and it will work. This error happens when a lot of documents have been sent to print if you only do a few at a time it seems ok
by unknown on Sep 28, 2004 at 12:37am Add comment
Hi
Some solutions to error C0084:
http://fix-your-printer.blogspot.com
by Jann31 on Feb 6, 2013 at 1:36am Add comment
