asked Mar 31, 2004 at 9:28pm
Epson Epson Stylus Color 660
epson 660 printer
All lights continue to flash. Will not print
It's not packing material. It worked great for 4 years and just started this blinking.I reloaded drivers, etc & no luck
It's a maintenance request request error. Which means the protection counter has reached it's limit. So you want to do the job right you will need to clean or replace thw waste ink pads and then reset the counter. For instructions on how to semove the pads try here http://epsonhelp.freehttp.com/wip.html You might as well do a little service to the printer while you are at it for info try here http://epsonhelp.freehttp.com/Printermaint.html
You will also need the adjustment program to reset the protection counter (waste ink counter) you can get it from here www.epson.co.uk or the SSC service utility from here http://inkjetprinterhelp.us/epsonSSC.html
I hope this helps.
Wes.
by unknown on Mar 31, 2004 at 10:14pm Add comment
