asked Mar 3, 2004 at 12:02am
Ibm IBM Laser Printer 4019
Error Message on IBM Lexmark 4019
HI! I am getting a Status code 9 on my 4019. When I press the check button it reads 2. I read the other posts and checked the fan...It works when I boot but shuts off after about a minute to display the 9. Bracket not broken fan turns freely! Any Ideas?
Thanks!
ZeuS905
I believe a 92 error is a fuser error. 97 would be a fan error. You probably either have a burned out lamp or a blown thermal fuse. If you have a meter, you can check the continuity of both. The thermal fuse is on top, under the fuser cover.
by moe on Mar 3, 2004 at 4:53pm Add comment
I get error 9 and when I press print/check it show error 2. Is there any diagram anywhere or does anyone have a service manual? I do not know what a fuser is, or what it looks like.
by O_Mighty_One on Apr 18, 2008 at 11:38am Add comment
I get the 9 error message and no documents prints. When pressing the start button the 2 error message appears. I am very much a novice and could use some advice in fixing this problem. - swatl
Open the lid, look straight down and you are looking at the fuser.
by moe on Apr 18, 2008 at 11:42am Add comment
I was never able to fix this printer, I still have it. I have no manual to determine what is really wrong or how to fix it.
by O_Mighty_One on Nov 28, 2008 at 1:04pm Add comment
