asked Feb 25, 2004 at 10:43am
Epson Epson Stylus Color 740
Epson Stylus color 740
Just bought a kit from you . Followed instructions to start cleaning cycle then pull plug when assembly moved over service station .
Pushed cartridges aside , but I don't see any sponge pads anywhere .
Please advise .
David..Just to let you know, I do not work for "fixyourownprinter.com". The sponge pad you are looking for is located on the Cap Assembly, whick looks like a felt pad inside of a plastic holder, with a raised rubber ring/lip around it. The cap assy actually sets over to the far right inside the printer. The Printhead Assembly/Print Cartridge Holder Assembly would set over the cap assy when its in its home position, at the far right of the inside of the printer. With the Top Cover removed, it is easy to see. With the cover on, you may need to use a flashlight to look into the right side of the printer...Denny Conway
by Denny Conway on Feb 25, 2004 at 10:56am Add comment
David: I wanted to let you know that there is a Service Manual available to use for troubleshooting, disassembly and servicing, in case you may need to do any further work on your Epson S.C. 740. An "EPSON Technical Repair Information/Service Repair Manual", for many Epson Stylus Inkjet Printers [including your "740"], can be downloaded in Adobe Acrobat format, [from the UK web-site] at " http://www.epson.co.uk/repair/inkjet.htm "...Denny Conway
by Denny Conway on Mar 17, 2004 at 12:48pm Add comment
