asked Jan 26, 2004 at 2:50pm
Epson Epson Stylus Color 740
Epson ink cartridge leaking?
I replaced the color ink cartridge (Epson brand) in my Epson 740. When I printed, a black streak ran the length of the page about 1 3/4 inches from the edge. I checked inside and found ink on one of the rollers. I cleaned it and ran the head cleaner. Ink was back on the roller. I cleaned the roller several times, but ink keeps showing up on it.
I'm guessing the cartridge is defective and leaking, but I hate to throw it out if that's not the problem.
If I do need to replace it, is there anything special I need to do to take out this full cartridge?
Pat: The cartridge is probably ok. That particular problem is normally caused by a build-up of dust, dirt, lint and hair that sticks to the wet ink on the bottom side and backside areas of the Printhead Assembly. That build-up acts like a small paint brush and transfers wet ink to those small rollers. Those small rollers then act like tiny paint rollers and roll the wet ink onto the paper as it passes below those rollers. Once those two areas are thoughly cleaned and then the small rollers are also cleaned, the problem will normally go away. Check for a couple of e-mails from me that should help in that area...Good Luck! Denny Conway
by Denny Conway on Jan 26, 2004 at 4:51pm Add comment
Hello Denny, i have the epson wf-3520 and i have the same problem. can you send me the information about cleaning the Printhead Assembly?
Tasos
- OmbashisT
Hi Denny, I have an Epson Artison 837 with a leaking Epson cyan cartridge, which spills small ink spot but not on every page. It ran out of ink, I replaced it with a new one which is also leaking. Can you email me instructions about how to clean the print head, or whatever else will resolve this problem. Thanks! - bgmojohands
I'm having the same problem with my Epson Photo 1200. What's the best way to clean the bottom and back of the Printhead? Do I have to remove it, and how do I remove it?
Thanks!
by unknown on Mar 3, 2004 at 8:51am Add comment
Hi Denny, - SusyCorreia
I am hoping you can help me. - SusyCorreia
I have an Epson Artisan 730 an the light magenta is leaking. Thanks - SusyCorreia
Scott: Normally, if you try to remove the Printhead Assembly, you will usually end up damaging it, or getting the Factory Settings thrown off. Its best to clean it while installed in the printer. Check for a couple of e-mails from me, with information on that area...Good Luck! Denny Conway
by Denny Conway on Mar 3, 2004 at 9:13am Add comment
Denny you ROCK. Thanks for the info, I will read it tonight when I get home, looks pretty thorough.
Thanks for your help!
by unknown on Mar 3, 2004 at 9:31am Add comment
I'm having the same problem with my Epson Stylus C60. When I print on glossy paper, I get those black streaks. I've tried cleaning them, but I guess I'm not cleaning it well enough cuz I still see the streaks. I'm running out of glossy paper and patience. What's the best way to clean this?
by Willie on Mar 8, 2004 at 11:08pm Add comment
You can clean the face of the print head. It's pretty easy to do. Use this link for info with photos http://www.epsonhelp.web1000.com/phface.html Just in case you can't access the site here is the text portion of the page.
"First thing is to get the carriage to move into the ink cartridge replacement position Usually pressing the paper feed button will make the carriage move. Once the carriage moves from it's "parked" position just unplug the printer.
In addition the flushing the print heads of old ink and unclogging it the face of the print head can attract dust, paper lint and pet hair. You can clean the face of the print head using a folded paper towel or coffee filter. Sometimes you will need to cut the paper towel or coffee filters into strips ¾ of an inch to 1 inch wide.
Then dampen the paper towel or coffee filter with warm distilled water (you will want the paper towel/coffee filter to be damp but not dripping) Now you place the damp paper towel/coffee filter in the path of the print head. Then pass the carriage over the paper towels/coffee filters to remove the foreign matter from the face of the print head.
As you slide the print head over the paper towel/coffee filters a few times you will start the see the debris is being removed from the face of the print head. It is not uncommon to perform this process several times to completely remove all of the foreign matter from the print head's face."
I hope this helps.
Wes.
by unknown on Mar 8, 2004 at 11:21pm Add comment
Hi Wes,
You posted quite some time ago... But even now in 2007 you help me enormously! My son needed to print out an assignment for school. Guess what. My C60 started leaking ink. :-(
Your analysis is dead on and your cure works! No more lines and spots and a beautiful printed assignment! :-D
Thank you very much!
Tonny.
- unknown
the photo link did not work. So I thought about your description and took a good look at the inside of the printing sliding carriage mechanism with a strong light.
I noticed a lot of black ink built up on the left side inside of this slot. So I scooped it out with a tiny spoon and then cleaned the track with Costco baby wipes. I made a few test prints which had black ink at the beginning which petered out. I wiped up again and made a good print. I don't know if the cartridge is leaking or if this is buildup over time. I will keep watching it now that I see the problem. - unknown
Wes: Thanks for the tip! Ran that through a few times and got a huge piece of dirt off! Looking at my 3rd printout, it still shows vague lines, but much better than what I had before. I guess after a few more cleanings, it'll be spotless! Thanks again!
by Willie on Mar 9, 2004 at 12:00am Add comment
Denny
I am havong same problems with my epson 440 stylus. Please send me the infro on print head cleaning too. Also do you have any comments on my other post today re error code KD0388
by ruxton28 on Mar 9, 2004 at 12:25am Add comment
Denny
I am having same problem with my Epson 44o stylus. Can you please mail me with the info on head cleaning.
by ruxton28 on Mar 9, 2004 at 12:28am Add comment
ruxton28: I have e-mailed you the same info that I sent to Pat...Sorry, but I have never heard of an error code KDO388 on an Epson Stylus 440 Printer. Epson Ink Jet Printers normally only cause Service Error Conditions that use SOLID and FLASHING Lights/Led's on the printers operational control panel...Denny Conway
by Denny Conway on Mar 9, 2004 at 9:24am Add comment
Pat, Scott S, Willie & ruxton28: I don't know if this will help you at this point, but "EPSON Technical Repair Information/Service Repair Manuals", for many Epson Stylus Inkjet Printers, can be downloaded in Adobe Acrobat format, [from the UK web-site] at " http://www.epson.co.uk/repair/inkjet.htm "...Denny Conway
by Denny Conway on Mar 10, 2004 at 10:48am Add comment
Willie: My Apologies, as it has been pointed out to me that the link I gave to you, is only for the older models of Epson Ink Jet Printers...Denny Conway
by Denny Conway on Mar 10, 2004 at 11:23am Add comment
Well Denny
I downloaded the SSC utility and used the agressive tool a couple of times to clean the nozzles and I got a part fix. Some of the colour is printing now. When I tried toprint a test pattern it said it was "printing to file" and wouldnt work. When I tried to use the Epson utility to do this I got the same result. The printer was not printing anything at all. I uninstalled the SSC utility and it still did'nt work so I used the uninstall feature in Norton System works and this solved that problem. I then used your methods to clean the print head but found the entrance tothe nozzles extreemly small. I think to do it properly you would need a surgical syringe. I used an eye dropper and forced hot water into the nozzle as best as I could. I left this overnight and this morning noticed lots of ink seems to have wicked out onto the strips of kitchen roll I laid under the print head. I will try to print again tonight. if that doesnt work I have my eye on a new printer at £53 delivered from PC world. Thanks again for all help received
by ruxton28 on Mar 11, 2004 at 2:05am Add comment
Thanks to all of you for the posts and the forum. I've been struggling with the same problem on my "beloved" Epson 1160 and these posts and links were just what I needed...printing perfect again in 15 minutes! I've already been shopping for a replacement, reading printer reviews on sites like amazon.com, and ironically, that is where I found the link to this site...it likely cost them a $400 sale. Hee Hee!
Never thought of using coffee filters...worked like a charm...and luckily this stopped me from continuing to use alcohol before it was too late!
by unknown on Jul 29, 2004 at 10:44am Add comment
Hi
I have Epson Stylus Photo 1200
The printer is a problem, I checked the power and this total led´s is flashing, what this problem?
I hope this helps.
Regards
Ferreira
[email protected]
Viseu-Portugal
by unknown on Aug 19, 2004 at 7:04am Add comment
Ferreira: I'm assuming that you mean that all the Lights/Leds on your printer, are flashing. IF SO, THEN THE FOLLOWING INFORMATION APPLIES: A Service Error where all LED's/Lights are blinking at the same time, is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and normally your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer. Some people actually wash the ink out of the old pads, by holding them under running cold water, then dry them out and simply reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work...THIS ADDITIONAL INFO POSTED BY "WES", MIGHT ALSO BE OF SOME HELP: Wes 12/07/2003 13:57:30 To see what's involved in servicing the waste ink pads try this http://www.epsonhelp.web1000.com/wip.html [OR] Tim H 12/10/2003 2:46:24 Subject: Epson Reset Program Download Location. after a long search for a reset program for waste ink, without paying, i found it. goto: http://inkjetprinterhelp.us/sscserve.exe . please check that your printer is compatible goto: http://inkjetprinterhelp.us/epsonSSC.html . this program has other features as well. TECH NOTE: Unfortunatly, the SSC Service Utility does not work on all Epson Printers and not on all Operating Systems, so you will have to check it out first...You will have to check on your particular Epson Printer Model, but you may be able to actually get that adjustment program for free, from www.resetters.com . I have never tried that source myself, but it was recommended by "WES"...Just in case the other sources do not work: You may actually need to go on-line to try and locate a "SERVICE MANUAL" or a "RESET PROCEDURE", to buy and download for reference in disassembly, troubleshooting and servicing. I have checked and you can find a SERVICE MANUAL for your "Epson Stylus Photo 1200", from 2manuals.com, at http://www.2manuals.com/product_info.php?cPath=2_18_39&products_id=147 , for around $10.00...Good Luck! Denny Conway
by Denny Conway on Aug 19, 2004 at 9:12am Add comment
I'm having the same black streaking problem as Scott S on my Epson photo 1200, but not just on gloss paper. I'm using non Epson Archival Ink on watercolour paper to reproduce watercolour paintings. Presumably the solution is the same Denny? If so please send me details.
by unknown on Sep 4, 2004 at 5:18am Add comment
Hi! I have been having problems with my printer. It seems to print one day and on another day it doesn't print. I use the cleaning tools on the printer ( the one that tells you to clean the head or the nozzle) but still does not print. What can I do?
I would appreciate it if you could help...
Helena
by unknown on Aug 14, 2007 at 7:25am Add comment
sounds like your printer has a clog try buying a cleaning kit for it. You can buy 1 from this site
by bethg on Aug 15, 2007 at 11:21am Add comment
Denny, can you send me the indepth instructions that are referred to in this string. I am having the same problem with the rollers leaving ink on the paper. Thanks much.
by chipb on Jun 22, 2009 at 3:01pm Add comment
I have the Epson r220 that prints on cd/dvd as well as paper.
I have a problem when I print on cd/dvd's that about every quarter of an inch there is a black dot in a straight line down the cd/dvd on the left side. I am sure that I need to clean the rollers but I dont know how to with out taking the machine apart. Does that sound like my problem or no?
by unknown on Dec 3, 2009 at 1:20pm Add comment
I have the same problem! - unknown
Hi, I have an epson printer with ink already installed to it. I just used for some printouts but after few weeks some are low while the black is empty, so i bough a new black cartridge and replace the existing. After few weeks it's empty again. My friend have same problem with me. Both are epson but diff model.
Can you help me fix this problem? My children needed a printer for their projects.
Thanks.
by unknown on Jun 2, 2010 at 2:46am Add comment
I do not think there is a leaking problem of cartridge.Because as per your explanation,the second cartridge is also empty.
So i think you have to choose a right font for your printer and have to regular printing.
And important thing is that do not print images more because it occupy more ink.
And shake your cartridge if this problem will again happen.
http://www.inkjetsuperstore.ca
by AshleyLewis on Jun 2, 2010 at 4:42am Add comment
But how come it's empty again? We just use it for some word printout and just few pages. But anyway thank you for your suggestion, I'll try it again and if same thing happens I'll check the site that you'd given me.
by unknown on Jun 7, 2010 at 12:27am Add comment
ANytime you turn the printer on. Or it runs a cleaning cycle it is using all the ink cartridges. Add to that the printer uses composite black as well as pure black. So even if it does not look like it the printer is still using the color ink cartridges. There really is no way to avoid it.
I think the person is a ink seller and does not know much about printers. I say this because her (AshleyLewis) answer really does not make much sense. And just wants you to buy ink from them.
I hope this helps.
by unknown on Jun 7, 2010 at 9:05am Add comment
I have a Epson CX6000, I place a four new ink cartridge in the printer, it was working at first, then two days later for some reason the black ink stop working. Shortly afterward, the printer said one cartridges was low when it was half full earlier that day. After running a couple of nozzle cleaning and lining test. The ink kept dropping and dropping. I check with a napkin and notice that there was ink leakage in the back. I don't know what to do or who to go to,
by Kobe26 on Oct 2, 2010 at 11:22am Add comment
Hey.. I am having this leaking spot on the paper same as the other users can you email me the procedure ? I will be very gratefull thanx
Email [email protected]
by unknown on Mar 14, 2011 at 10:20pm Add comment
Epson Stylus r1900 - printer leaves big smears of ink and doesn't print accurately - of you could also send me email help instructions I would be very thankful
by unknown on Oct 1, 2011 at 1:31pm Add comment
Hi
I also have a r1900 that leaves ink streaks across the page once in a while.
I am using refillable dampener cartridges.
Can I also have the help instructions?
Steve
by requiredwhen on Dec 12, 2011 at 11:52am Add comment
I have an old Epsom stylus color 740 which needed a new cartridge. But after I replaced it with several problems, I now have ink printing on the edge of the page on the right side--front and back of the paper. I need to know how to move the cartridges out of that area to clean it. I found instructions on how to do that but now can't find it. Please direct me! Thanks.
by anon1 on Mar 21, 2012 at 7:18pm Add comment
Push the paper feed button. Once the carriage moves unplug the printer. And you can now move the carriage all you want.
by unknown on Mar 21, 2012 at 9:12pm Add comment
Am havin the same problem.my epson p50 is really leaking even after a thorough printing head cleaning,I don't know what to do!
by paschaline on Jun 18, 2012 at 8:45am Add comment
I'm having similar problems with my Epson Photo R2400.
Can you please send me the instructions on cleaning the print head.
Thanks.
by BSM on Nov 29, 2012 at 5:36am Add comment
My Epson workforce 1100 is leaving a black streak on the back side (left). I would really appreciate it if you sent me the instructions for cleaning the rollers. Thanks very much
by Martha Hayden on Mar 26, 2013 at 5:11pm Add comment
I have an Epson Artisan 837 which started to leave red blobs of ink on the paper. I installed all new Epson cartridges. Cleaned the heads 3 times, aligned the heads and have the same red ink blobs.
by unknown on Apr 2, 2013 at 6:39pm Add comment
I could really do with some help.
I have the same problem on my Epson Stylus Photo R220...
Dotted lines straight down the CD
Can anyone suggest a remedy or email me the cleaning instructions that seem to be doing the rounds on here...
PLEASE
Thanks in advance
by unknown on Aug 11, 2013 at 7:10pm Add comment
I am having the same problem as PH1994 which is on my Artisan 837 my light magenta keeps leaking huge blobs of ink on everything. I have head cleaned multiple times, I have changed the cartridge to a new cartridge now 3 times. Help!
N
by unknown on Sep 4, 2013 at 11:07am Add comment
I am getting blue (cyan) ink blobs. I have an Epson Artisan 730 printer.
by Desert Dweller on Sep 18, 2013 at 4:25pm Add comment
Hi, all colour ink for my Epson Workforce Pro 4540 all in one.
When printing a good amount of yellow ink spews out onto the paper and continues but gets a little less as you print.
I opened up the door panel where the inks are inserted. You can see right inside. I used a flashlight and notice yellow ink is very noticeable inside. I pulled out the cartridges but they are not leaking. I may have to buy a new printer :(
Phil
by unknown on Mar 19, 2014 at 12:52pm Add comment
My artisan837 and 835 is leaking ink (cyan) and photos are printing green, I used the utility to clean the print head but it did not work. I also cut off the printer after cleaning the print head. Can you give me to instructions on how to clean up this problem. The 837 is leaking cyan all over the page.
by unknown on Jul 23, 2014 at 8:28pm Add comment
hello!
i'm having a problem with my EpsonL110 that leaks ink at the bottom of the unit.
i have refilled the ink tanks and yet the ink just spills out and leave a mess in my table most of the time. the print is good but the unit itself is leaking ink..
what will I do. hope you could help me with this. thank you!!
by unknown on Sep 25, 2014 at 11:52pm Add comment
I am having the same problem with my WP-4540. I get a blue streak down the entire right side of the page. I have changed ink and it still happens. I would appreciate any help if figuring out how to fix this.
by ladyallenfla on Oct 22, 2014 at 7:20am Add comment
Hi, I am having the same problem I get leeks when I print on epson photo paper, and the printer Epson XP-422 is only a week old.
Can you advise please.
Eddie.
by unknown on Nov 11, 2014 at 1:54am Add comment
Hi I have the same problem I get leeks when I print on epson photo paper,
Can you help please.
Sanddancer.
by unknown on Nov 11, 2014 at 1:59am Add comment
Had a leak issue from the printer head. After cleaning the print head now can not get the printer to complete the "start up cycle" it will start then restart a couple of times then power off. Restart yields same result. There is no error message. If you remove the cartridge it will state cartridge is not inserted. If you try & start with cover open it will warn you to close the cover.... the message and display works?
Any ideas?
by burntmud on Dec 31, 2014 at 4:53pm Add comment
Hi
when I print, the print comes out wet and smoggy.
I cleaned the heads, but on plain paper it's all fine. As soon as I print on Epson glossy paper. the page and ink is wet to the touch.
Can you please email me the solution to my problem.
Thank you
Mark Toporek
by unknown on Jan 16, 2015 at 10:18pm Add comment
My Epson WP-4530 has the yellow streak condition. Can you email me the fix? I wiped out the inside of the printer with a puffs about a month ago, but the yellow ink is back on my documents again. Help and Thank You!
by unknown on Jan 20, 2015 at 10:37am Add comment
So I figured out the fix, it is best to call Epson AIO/Inkjet support at 562-276-4382. they should get you going, worked for me. they will ship you a replacement unit, but they want a CC deposit. So put on your big boy (or big girl) pants and give them your credit card and they will ship you a replacement. Just be sure to ship it back out and keep a copy of the receiving scan from FedEx and make sure they don't charge you in the next two billing cycles. - drwifi
My epson artisan 730 is leaking all of my light magenta ink. I have tried cleaning the heads and test prints all have magenta ink blobs. Please help!
by unknown on Feb 8, 2015 at 9:11am Add comment
I'm having the same problem with my artisan 730, except it is my cyan that is leaking. When putting in a new cartridge the printer went through it's normal setup to accept the new cartridge and by the time it was over and i printed a test page, the cartridge was empty again. There are blobs of ink all over the paper. Any help would be appreciated.
M.
by mwilson38 on Feb 15, 2015 at 6:33am Add comment
printer epson stylus Dx7450 not printing . Hoe can I identify which catredge is empty
by unknown on Feb 18, 2015 at 1:48am Add comment
Yeah!! Same problem is here in my office printer. I have use Epson Series printer that is leaking ink cartridges in cartridge box we are repair manually but that s not working in printing. We are change cartridges in but that problem is not gone in site tell me suggest good Cartridges to best my Epson 1160 printer. Can you give good idea what can I do.?
by AmandaJSmith on Mar 5, 2015 at 12:03am Add comment
I have an Epson PhotoR1900 and also have the black lines running across the page- any type of paper- from the printer head. Can you please send me the instructions on how to clean the printer head? Thanks!
by unknown on Mar 16, 2015 at 10:54am Add comment
Dear
you no need take out all cartridge.you only repace the cartridge that was broken.
http://www.printer-product.com/
by brianhu on Apr 10, 2015 at 7:28am Add comment
I have a WF-4530 and I love it. However, it is now leaving dark blue stripes down the right side of my papers when printing. It doesn't matter what kind of paper.
Is there an easy fix for this?
Thank you!
by unknown on Jun 5, 2015 at 9:04pm Add comment
TiffanyAcuff...In all likelihood the ink system is failing. I have seen this happen a number of times with this series of printers. Probably not economical to replace the defective part. Hope this helps.
by unknown on Jun 6, 2015 at 8:50pm Add comment
Please help me! My Epson Artisan 1430 is sick! I have black lines running on the outside white area of my art-prints. I have changed the cartridge, cleaned the inside (where I saw there was flooding of black ink)and out of ideas except to trash the printer since the prints are my bread and butter and I had to refund customers for not having the prints in time. What do I do? Its only a year and a half.
by unknown on Jun 28, 2015 at 8:15am Add comment
I have an Artisan 837. Replaced both the magenta and light magenta cartridges, tried copying something and there's wet, dark pink ink all over the page. I removed both of the cartridges and stuck a Q-Tip into the space and it becomes saturated especially on the magenta slot. I had another magenta cartridge so put it in. Same thing happening. I checked the other 4 cartridges and they are virtually dry.
by unknown on Jul 24, 2015 at 2:16pm Add comment
Posting this cause it worked for me. I have an Artisan 837 that was leaving pools of blue on the page. I tried Epson's recommendation of cleaning the print path by pressing the copy button on the control panel (with nothing on the flatbed). Printed 5 pages and the last 2 were clean. Did a test print and the problem was back. Repeated a few times with the problem reocccuring. Switched out the cartridge. no better and now the printer doesn't recognize its own brand cartridge. Yet, it accepts the 3rd party one.
I opened up the machine like you would to install cartridges. Using paper towels, I dried up the excess ink I saw on the area in front of the little white rollers. I also used a hair dryer on the cool setting to help with the drying. I made sure it was as dry as possible and then repeated the cleaning path process successfully. I've done a couple of regular prints since successfully.
by patm64 on Sep 11, 2015 at 11:48am Add comment
Well that worked temporarily. Throughout all of this, the blues have been off in my printouts. - patm64
Well that worked temporarily. Throughout all of this, the blues have been off in my printouts. I don't know what else to do at this point. Never had this problem with Canon. I was thinking about buying the next level of Epson prior to this but leery of Epson - patm64
I'm reposting since I haven't seen recent responses from Denny. I have an Epson Artison 837 with a leaking Epson cyan cartridge, which spills small ink spot but not on every page. It ran out of ink, I replaced it with a new one which is also leaking. Can you email me instructions about how to clean the print head, or whatever else will resolve this problem. I could find any excess in on rollers, etc, but the entry point for the cyan seemed a little wetter. Thanks! - bgmojohands - bgmojohands
BTW, the cyan isn't being recognized so I can't even print at all - bgmojohands
I have an Epson Artisan 730 which started to leave Light magenta blobs of ink on the photos but not document prints. I installed all new Epson cartridges. Cleaned the heads 3 times, just when the nozzle check came out good it told me I'm out of magenta. I replaced the cartridge and have the same magenta ink blobs. has anyone found a fix for this, it seems pretty pronouced. Thanks -HarM55
by HarM55 on Nov 23, 2015 at 4:55pm Add comment
Oh I also have an Artisan 710 that stopped printing altogether after my yellow ran out. I can't even get the nozzle check to print. Says I have ink and sounds like its printing but all I get is blank paper. Ran the print head cleaner and I see the ink levels reduced but still, blank paper. Any help would be much appreciated
by HarM55 on Nov 23, 2015 at 5:00pm Add comment
I have an Epson Artisan 837 that keeps leaking the Cyan Ink as well. I have actually been stupid enough to replace the cartridge (which I bought at Best Buy for $52 with all other colors except black - 4 times now in the last 8 months) continuously as I have kids in school who need to print often. I need to get this fixed or buy a new printer... heck, I could have already bought a new printer by now but now I have a ton of 'other' ink colors so I'd like to keep this printer but I MUST fix the issue now!
Thanks for any help, Tim
by timville on Jan 28, 2016 at 1:16pm Add comment
I can keep changing the cardtridges for new ones. I print out one page. Next day I start it up again but cartridges are empty. No streaks on the paper but no ink in the cartridges either. The pad in the back is soaked with ink. What is the matter with this epson? it an sx130
by duped on Mar 12, 2016 at 7:43am Add comment
Hi Denny, I have both streaks of black and puddles of black on my copy. I changed the black ink cartridge yesterday. What do you suggest? Thank you for your help.
by Becky on Apr 7, 2016 at 10:06am Add comment
I have an Epson WF-2350 - Becky
Hello Denny. I'm having a similar problem with my Epson Artisan 837. I'm getting blotches of blue ink on every page that I print. I know it's not a problem with the cartridge, but I can't seem to figure out how to get at the underside bits that would I assume need cleaning.
by sbwiliams on May 7, 2016 at 10:54am Add comment
Hello. Like many on this board, I have a 837 leaking cyan on the page. I saw a few responses about instructions for cleaning it up. Does anyone have these or can point to where I can find them? I found a service manual, by figured I'd ask before disassembling. Thank
by Mongo2001 on Mar 2, 2017 at 8:17am Add comment
i have the same problm on epson 1100. Black ink streaking nd dripping until empty. Can you pls help me. Thank you.
by Iya on Mar 19, 2017 at 3:57pm Add comment
Look on U tube, there are a lot of posts about blobs of inks leaking and one man took his Epson printer apart and found the cause. I have an Epson Stylus SX353WD with an error code on the screen which says that the ink pads have come to the end of their life and the lights are flashing. This is a result of an Epson black leaking into my Epson printer, yet Epson want to charge me £118 for a service. I have had the ink pads removed, washed and replaced and the printer was working fine till this error code came up. Epson told me to continue printing in an e-mail, knowing full well my printer would be locked. Does anyone know the code to unlock it? They make wanna cry look like choir boys.
by Rippedoff4 on Aug 19, 2017 at 4:51pm Add comment
