asked Jan 14, 2004 at 6:29pm
Apple Apple StyleWriter II
LaserWriter IINT to G
I just bought a used Apple LaserWriter II G contoller board to convert my II NT to ethernet capable.
Unfortunetly, it doesn't seem to be working. Now I get a constant blinking green light (like there is a job printing) and every minute or so it starts to wind up like it's going to print a page, then stops within a second or so.
Any suggestions?
Lane
Turn it off, select the switch on the board to 4 and turn it back on. It should do a config page. I assume if you stick the NT board back in it works?
by moe on Jan 14, 2004 at 6:37pm Add comment
I'm assuming that your talking about the push button switch on the back panel? That switch was set to "0", I just turned it off and set it to 4. It seems to be doing the same thing...It goes through the startup routine of the various lights cycling, then goes to a blinking green light, then repeats the light cycle. The printer also briefly starts to run for about 1/2 a second at the start of each cycle.
Thanks!
Lane
by unknown on Jan 14, 2004 at 7:39pm Add comment
