Adrian
asked Dec 2, 2003 at 2:01pm
Epson Epson Stylus Color 740
Epson Stylus 740 won't print red ink
My Stylus has stopped printing red. I've been through the clean cycle about 10 times, and used a cleaner-cartridge, but with no joy. I've also changed the cartridge. Something is obviously clogged up - any suggestions on how to clean would be much appreciated.
You could have an actual hardware problem but, it's most likely just a clogged print head. You can get the cleaning solution here http://www.fixyourownprinter.com/kea0.html it's not expensive either.
If you want to see what's involved in print head cleaning try this link. http://www.epsonhelp.web1000.com/printhead.html
I'm sure you will get another longer answer soon.
I hope this helps.
Wes
by unknown on Dec 2, 2003 at 2:34pm Add comment
