asked Oct 16, 2003 at 11:24pm
Hp HP Color Copier 120
HP LJ 111 PRINTER
This printer printout shows a 120 vertical lines across the whole paper together with the orginal printout.
It happens only after the printer is heated up for a few hours later.
What is the problem ?
Maybeu should try cleaning the rollers inside the printer. Some can be very dirty. Does help some times...
by unknown on Oct 17, 2003 at 1:33am Add comment
You actually counted the lines? The vertical lines are an engine test. You can initiate one by looking at our troubleshooting section. If the lines match up, then you should replace the DC controller board. They are available in Moe's Deals section of the site.
by moe on Oct 17, 2003 at 11:10am Add comment
Thanks. I will do some testing.
Will let you know.
by unknown on Oct 19, 2003 at 6:11pm Add comment
total of 117 vertical lines.
by unknown on Oct 19, 2003 at 6:52pm Add comment
It is caused by PCB board.
by unknown on Nov 28, 2003 at 2:06am Add comment
