Mikel
asked Sep 20, 2000 at 5:30pm
TI microlaser pro 600
I have a TI micorlaser pro 600 and it has an error
coded "optical sys err" on the lcd display. Any suggestions
to the cause of the fault and which internal units to replace
would be great.
Cheers
Mikel
That's a bad one. Failure of the laser scanner assembly. That printer is extremely difficult to get apart. You have to remove the hinge down front panel in order to remove the cover. No way you can do it unless someone showed you all the hidden screws and catches. You'd definitely break something
by moe on Sep 21, 2000 at 8:40am Add comment
