Maggie
asked Aug 7, 2003 at 5:37pm
Epson Epson Stylus Color 660
Epson Stylus 660 Paper only loads half way & stops
I have problem with my Color Stylus 660 inkjet printer. Every time I send a signal to print, the paper only load half way and stops completely. Then the light of paper out stays lighted. I cannot print even the TEST page. What will be the problem? Would someone be able to give me some indications of how to fix this problem? I just want to know if there is something that I can do myself to fix it before taking it to a technician.
Maggie: It sounds like the paper may be running into a possible foreign object and stalling or feeding crooked. Remove all the paper and use a flashlight to look carefully into the paper feed-in area. Look for a pen, pencil, push pin, paper clip, candy, etc. If you can't see anything, then actually pick your printer up and turn it upside down and shake it a little. You are trying to dislodge anything that might be stuck in the paper entrance area. If nothing falls out, then turn it back over and use the flashlight to once again look inside that area. sometimes you'll see an object that may have moved over into view while you were shaking the printer...Good Luck! Denny Conway
by Denny Conway on Aug 12, 2003 at 5:08pm Add comment
