petanque
asked Mar 10, 2020 at 5:12pm
Epson Epson Stylus Photo RX620
service required
Error message saying "service required"
If you look on this thread: https://www.fixyourownprinter.com/posts/64702 you might find a few useful tips to get this working again.
You could try using the "SSC Service Utility" but I've heard reports of it not working on this model. Also needs Windows XP/Vista/7 (won't work on 10).
Another alternative is: "To clear the error message and reset the printer - Hold down the STOP and the B&W Start buttons while powering on the printer. This should clear the error message and reset the printer"
Long story short, you need to reset the printer (there is a counter that has reached a limit, shutting the machine down) - then once it's working again, find and clean the "waste ink pads" (small bits of foamy sponge to mop up ink used from head cleaning).
Or, if the printer will not be moved about much, and you have space, install an external bottle/container for the waste ink to go into.
This is a very common fault with Epsons, and more people should be made aware of this. It'll happen to every Epson eventually.
by spotify95 on Mar 31, 2020 at 5:29pm Add comment
People in Luxembourg speak the German, French, and Luxembourgish languages. The linguistic diversity of Luxembourg is rather diverse according to a fractionalization scale which for Luxembourg is 0.644. The followers of Christianity are the religious majority in the country. 85.4% of Luxembourg's population live in cities. This percentage comprises the urban population of Luxembourg. The rate of urbanization in Luxembourg is considered to be 1. According to data on inbound tourists in Luxembourg, 945,000 tourists arrive in the country each year.
by NextelBexten on May 16, 2020 at 6:15am Add comment
