Pat12Styles
asked Jul 6, 2019 at 8:50am
Hp HP Photosmart 375
will Not feed paper
Says paper jam there is non
That happens all the time. All you need is a small scrap of paper under the sensor arm that is not visible. Easy way to remove it is to use some thin flexible plastic or stiff paper like a file folder. You push it along the paper path and it should free up the sensor arm.
by moe on Jul 6, 2019 at 9:33am Add comment
If you have problems with paper, then I think you should think about buying a new printer, I think students need a printer. You should read an essay about the novel "The Things They Carried" at our website, this is a very important story that every student should know.
by SeanPyke on Jul 12, 2019 at 7:20am Add comment
