mycheapprinter
asked Jun 17, 2019 at 8:51pm
Epson Epson Stylus CX7400
How do I open my all in one to clean it?
There is old ink inside, the full magenta cartridge wouldn't print, then all paper would get crooked and jam. Now the paper won't move to print any paper. Maybe if I clean it that will help. I don't know how to open it.
Paper jams and other printer issues can be really frustrating. Fortunately, most minor issues can be fixed with a simple clean. Usually, all you need to do is run the automatic cleaning function that most printers have. If that doesn't work, you can manually clean the paper rollers and the cartridges. You just need a clean cloth and some water. Your printer can be clean in no time! Source: https://www.wikihow.com/Clean-a-Printer
James Tinker - Online academic writing
by jamestinker91jt on Jul 4, 2019 at 2:47am Add comment
Use a clean, dry cloth to dust the case. Use a clean cloth dampened with warm water to wipe it clean. If sticker residue is present, use isopropyl alcohol or rubbing alcohol and a lint-free cloth to remove the residue..
support
https://support.hp.com/us-en/document/c00847274
=> Law Dissertation Help UK
by smithsera on Jul 4, 2019 at 4:36am Add comment
