[email protected]
asked Apr 27, 2019 at 10:55am
Hp HP Color LaserJet CP1518NI
Cartridges 1 year
Purchased color cartridges April 30, 2018 for approximately $220. Was notified this morning that the magenta needed to be replaced. All of the color cartridges are very low. Very frustrated. Please help. Is there anyway for me to get more life out of these toner cartridges?
You can just ignore the "Low Toner" warnings and keep printing with these cartridges until you lose print quality. Don't change them all at the same time -- the toner doesn't get evenly used at the same rate so most likely you will only need to replace one at a time. However, if your printing is essential you might want to have a full backup set of toner in stock though. It would be rare for all 4 cartridges to print all the way to 0% Left -- usually at least one of them will fail a tad early with a print defect, and at that point you can identify the failing cartridge and just change them one at a time as defects occur.
by ofcourse on May 3, 2019 at 9:45am Add comment
Can you please tell me which color cartridges you have purchased? Then I could say something and give any solution.
by 800tonerllc on May 13, 2019 at 2:51am Add comment
