John brown
asked Dec 6, 2018 at 3:16am
The Magenta clogged
I have a Epson Wf-7620. I don't do a lot of printing, but I want to be able to print when I need to. I was preparing to print my Christmas cards when, the printer would not print. The Magenta was clogged. I was going nuts. I ended up having to use a friends printer to print my cards but it wasn't a great job.
Either using the Compatible Epson cartridge or original Epson cartridge it always leads to one or more clogged and blocked nozzles that require cleaning. Sometimes, even the cleaning cycles of Epson printers are not able to solve the issue. Print head clogging issue is inevitable because ink residues dry up over time and are collected in the nozzle. You can buy Printers Jack Printhead Cleaner Kit from amazon. Unlike most printer cleaning products, Printers Jack cleaner doesn't damage your Epson printer. Hope this helps.
https://www.amazon.com/Printers-Jack-Printhead-Cleaner-WF-7610/dp/B07JZDCLBN/ref=sr_1_9?ie=UTF8&qid=1543304366&sr=8-9&keywords=epson+printer+cleaning+kit
by Peter millian on Dec 6, 2018 at 3:20am Add comment
