orst88
asked Nov 26, 2018 at 10:15am
Hp HP Color LaserJet CP3505DN
Black toner leaked into printer cavity, now no colors printing
Using refill toner on black cartridge, seal unfortunately failed and black toner leaked onto other cartridges and behind. Vacuumed up, but now no reds or blues and only hints of yellow show when printing.
Best guess is that the toner is covering the plastic prisms that the laser light shines through to form the image.
by moe on Nov 26, 2018 at 4:08pm Add comment
I appreciate your response. Can a "jack-of-all-trades" guy attempt to clean? Where are the prisms accessible?
by orst88 on Nov 26, 2018 at 5:01pm Add comment
http://www.lbrty.com/tech/Manuals_HPC/CLJ3000_3600_3800_CP3505sm.pdf&ved=2ahUKEwiHr9rl4PPeAhVLwMQHHSb-BnkQFjAAegQIBhAB&usg=AOvVaw12CVyZAa78iF_zXUiLEOxD
by moe on Nov 26, 2018 at 10:43pm Add comment
Thank you. I accessed the manual but your full link as provided did not open.
(Browsing the manual, the laser/scanner system (pg54) appears the focal point.)
by orst88 on Nov 27, 2018 at 9:38am Add comment
pg 63 shows the location. Since the black is on top, it is likely the toner migrated down on the other lenses. You can try wiping them down with a paper towel dampened with window cleaner.
by moe on Nov 27, 2018 at 1:31pm Add comment
Am appreciative of your assistance. Will respond one more time after my attempt - to divulge whether successful or not.
Orst88
by orst88 on Nov 28, 2018 at 4:51pm Add comment
Sometimes there are things in life that a commoner just cannot fix, regardless his talents. Disassembling this thing appeared daunting. Rather, I first vacuumed every crevasse, then compressor-aired the unit until no more toner dust exited the vents etc. To someone in the industry, this may well have been the dumbest thing I could do. Ultimately the error: "Turn off then on" which would not resolve. No regrets. It was a loyal printer. Gave away, possibly to be fixed.
I will be more caution with my backup printer - a dated but new HP color Pro M452dn. Looks better too.
Thank you again. Over and out.
by orst88 on Jan 8, 2019 at 6:25pm Add comment
