byemg49
asked Aug 23, 2018 at 10:55pm
Hp HP LaserJet 4050T
Tray Three Removal
How do you remove tray 3?
You have to split the machine in half.
Start by removing the 2 very long tray 1 p/u asm screws, remove screw on the left side under the fan, remove the formatter, disconnect the purple cable from the lower portion (under where formatter was) and lift printer straight up.
Then the lower unit can be accessed from the top.
If you remove the screws that connect only tray 2 to tray 3 you shouldn't have to remove the metal plate and rails of tray 2 to reach tray 3
by jessicamichael on Aug 24, 2018 at 2:07am Add comment
