ppope
asked Mar 8, 2018 at 12:03pm
Hp HP LaserJet 4000TN
79.00FE Printer Error
Printer was working fine, then suddenly it began displaying this error: 79.00FE Printer Error. I have power cycled it multiple times, and only once did it print the test page - barely. Upon Test page completing it revered back to the above mentioned error. HELP!!!
https://www.fixyourownprinter.com/posts/1121
If it is a 610n or 615n network card, you can fix it by baking in the oven. Support it off the pan, component side up for 8 minutes at 375 degrees Fahrenheit. Remove the plastic front first. The 600n cards can't be fixed, but they almost never go bad.
by moe on Mar 8, 2018 at 11:37pm Add comment
