jdanham
asked Feb 17, 2018 at 11:28am
Hp HP Color LaserJet 4650DN
Center of page, tire tracks plus imprint pattern
Swapped out all toner, vacuumed and wiped down visible rollers etc. but almost exactly in the middle there is a visible track, and holding the sheet in the light a certain way you can see a visible impression pattern about 2" wide as if the roller/feed settings were ironing the paper as it passes through the path.
The only thing that can do that is the fuser assy. You will need to replace it.
by moe on Feb 17, 2018 at 4:54pm Add comment
