nasserhassan
asked Feb 1, 2018 at 2:37pm
Hp HP LaserJet P3005X
it says ( downld file now 1/6 send rfu up grade )
These P3005 printers are famous for formatter control boards going bad, if you tried a firmware upgrade then it might have locked up and got stuck on that screen. If you did not then it probably has trouble reading the firmware chip.
You can try taking the board out to heat in an oven to try and get it working again, see Moe's response on this link https://www.fixyourownprinter.com/posts/55786
If that doesn't work or you don't want to try it then search the internet or Ebay for a P3005 formatter, most are probably used and make sure it says DN or X or for Duplex models, boards coming out of N printers have duplexing disabled.
by Jay145 on Feb 2, 2018 at 9:35am Add comment
http://www.printertechs.com/shop/hp-laserjet-p3005-formatter-board-q7848-61006
by ofcourse on Feb 15, 2018 at 11:30am Add comment
